As fate would have it, I just got a clean print. I don’t know what resolves the issue tbh but I think it is related to the feeder. My last tension setting was somewhat towards the top and middle. Picture attached.
also my build plates are usually fairly clean with a thin glue layer.
Filament I use a mix of Ultimaker and Polymaker. In this case it’s polylight PLA.
SandervG 1,522
Hello, thank you for your post and welcome to the community!
Could you include a picture of your feeder, showing the top and the tension it is set at now?
Could you also include a picture of what your first layer looks like?
I believe the fan shouldn't be on during the first layer, but if there would be small strands of filament in there they could block the fan at a later stage so in any case its good that you removed them.
Are you using Ultimaker PLA or a different brand? Which weight are the spools you are printing with?
Have you also cleaned your glass plate? I don't see that in your list. Unless there is a lot of glue on there, it shouldn't prevent extrusion, but it could influence the adhesion of your first layer.
Some more questions, looking forward hearing from you!
