You doubled the steps/mm that is a lot!
Cura doesn't know the value of s/mm that is stored in the firmware of the printer. Cura tells the printer to raise the Z-axis x.xmm, the printer then knows how many steps the Z-stepper has to make (with the value stored in the firmware)... In your case the Z-axis will be lowered, not raised...
So I find the very strange that it is impossible to print an STL sliced with Cura! Check settings, compare them with the settings in Creality Slicer.
1
gr5 2,330
Do you use 1.75mm filament or 3mm filament?
