Yes, attached is the original (v1) and v2. The v2 is using the setting changes from here:
While improved, see the last comment. That appears to be what is happening in my case.
I made a couple of tweaks:
1 - set min wall flow to 50% to stop inner walls being printed on top of each other.
2 - set inner wall width to 0.5 to stop the inner wall dropping out where the overall wall thickness is less than 1.5mm.
This now takes around 17.5 hours to print which is 3 hours faster than the original project.
Hope this helps.
Oh, yeah, I also changed the z-seam position as the sharpest corner scheme rarely does what you want.
Thanks burtoggle, I'll give that a go next.
Actually, I think it will do better if you turn off combing completely and increase the min wall flow to 80 or thereabouts.
This was a great learning example.
Thanks
Torgeir
Copy that, I'll give that a go. I think I'll do this next one in standard PETG as a test.
What is the thought on speeding up the print and increasing layer height? Ideally I'd like to go to 30 mm/s print speed and 0.26-0.3mm layer height with the 0.6mm nozzle but I'm hesitant to do that at the moment. I also have a 0.8mm nozzle on order and will re-build the part with 1.6mm wall thickness to make it a two layer print.
One other question, how did you determine the z-seam location in this example? Its not readily apparent, and there doesn't seem to be an easy way to grab the coordinate within Cura.
Why not, this is a good way to save printing time, -but now you are in experimental mode!
It all depend very much of the heat transfer capacity of the hot end your printer is using.
Saying so, I know nothing about your printer for sure.
Your model shape should fit well in using 0.6 mm nozzle, I'll think.
I would test with a smaller model with same type of shaping angles hole etc. as your original, -but can be used as a test object to tune up the parameters -with max print time say 45 min.
(It is a good help in using Cura in playback mode to have an overview of the printing path.
In your above example, the center of the wall line was printed 2 times, I.E. this line was kind of doubled or become to high.
By studying the path of one complete layer, you could see this very well, I've never seen this before.
So seeing your print was an eyeopener to me..)
Well, just a thought.
Good luck.
Torgeir
Hi Torgeir,
I'm kind of using the print that is on the bed at the moment as a test. Upped the speed to 30 mm/s at the moment and it looks pretty good.
A scaled down example would be useful.
That's great..
You can specify in the menu "Shell" where/how you can "locate" the Z seam.
Just put Z in the "search setting" then Shell pop up.
Hmm. By using sharpest edge, the seam is less visible at this place in your nice curved object. 🙂
Torgeir
Edited by TorgeirTorgeir,
Yes, I get where that is entered in the Cura settings. What I'm asking is how to find that coordinate in the model...I could probably try relative and pull the coordinate out of CAD, but I'm hopeful there is an easier way within Cura. Google searching came up empty handed so maybe not.
Edited by samc99us
Hi samc99us,
Sure there is, just open your gcode (the actual one, that's saved to be printed) file in Cura (here Cura 4.6.1). Cura will open the model in sliced mode, so you can only view it manually or replay it. The later versions of Cura will open with selected filament color and shows colored lines or different colored lines if there is some width that's use several lines. Inner wall, infill, outer wall etc.
Suppose you use gray PLA, then your model will appear gray if you drag down the layer number slider bar on the right side.
If you then pres start replay, the start point where it start printing will be the layer shift point.
In multi layer walls it is not easy to see the seam, as this is more a problem for single wall print and here it will be very easy to see the seam. Cura may start with any of the lines in a multi line wall, but at the same point. In your model there's two sharp angels Cura might use, but the one I've used here is on the right side.
So, here is a picture of the whole issue, using Cura 4.6.1:
(This actual picture here, also show the selector panel for the various "layer type lines" with colors used.)
Here you can see the start point of layer 232 -just where the green line start!
If you want to find it in the gcode file, use this tool:
(I'm using this one quite often.)
I'll hope this clarify the issue.
Regards
Torgeir
Edited by Torgeir
Torgeir,
Nope, I totally get that, its basically the same view as the Preview menu....that start location was defined by burtoogle, but how did he determine the correct coordinates in the first place. Again, even in your view, no coordinate is given unless you count the lines on the print bed or some other way. Google was not help.
The good news is these new settings are working very well!!
Hi samc99us,
Understood, I'll think the best one to answer this one is @burtoogle for sure.
Regards
Torgeir
Nope. Haven't found a single thread pointing to how to find model coordinates in Cura.
Hi samc99us,
Took some time to make some better explanation of this coordinate use in the Z seam setting in Cura.
The first mode is Z seam relative coordinate setting.
Here's a picture of your print in Cura 4.6.1
Hopefully this is self explained!
IMO. This is the closest you can go using mm to find position like this in Cura.
Next picture is showing the situation when Z seam relative is deselected.
I've learned a few thing, by your question and I hope you find some use of it!
Regards
Torgeir
Edited by Torgeir
Hi samc99us,
I've just revised my previous posting Z seam relative/absolute coordinate setting.
Thanks.
Torgeir
Thanks Torgeir, I think the best way is to do relative and pull the coordinates out of Solidworks. IMO Cura should implement a way to grab a model coordinates when hovering over the model with your cursor. The other way this is done is by just looking at the model dimensions in the lower left and cutting them in half with the relative option checked to put the seam on an edge.
Edited by samc99us
burtoogle 505
Could you please provide the project file? Do File -> Save and attach the .3mf file to this thread. Thanks.
