Thanks for the advice, I'll take a look. On an UM3 the fans are either side of the print head so I'll get a print going and see if they come on or not!
I’ve found that the side fans don’t activate during a print but they still work if I manually adjust their speed in the settings menu. I definitely haven’t adjusted any settings that could have caused this behaviour, and am wondering whether I’ll need to replace the fans?
geert_2 556
Have you checked if the nozzle cooling fan is working? If not, this would give this phenomena.
On an UM2 this is the little fan behind the nozzles; but I am not sure where it is on an UM3. Occasionally this fan may suck up hairs and strings of filament, and get stuck.
