Please help! With print?
Posted · Please help! With print?
Can someone advise on a possible ‘fix’ for these printing faults on this ‘Benchy’ please ? I’ve tried different settings but can’t seem to sort this out. On the side of the cabin.
    Please provide more info.
    -What material
    -Printer model
    -Printing temperature
    -Print speed.
    Also, on your printer, make sure there is no play for all axis and the coolinf fans are working.
    Hi, sorry.
    the material is PLA Matte from Filamentive.
    the printer is a Creality Ender 5 Pro with a SKR 1.4 turbo motherboard
    printing temp is 210 at 60.
    the hotend is a E3D V6 using standard brass 0.4mm nozzle
    retraction is at 3.8 with speed set at 60
    Posted (edited) · Please help! With print?
    1 hour ago, quad121 said:
    Hi, sorry.
    Not got first hand on a Ender but the retraction settings might be to fast and to short. Try 6mm at 25mm/s, if you have retraction set to fast you can make a delay in the start of the filament flow again after a retraction and that might be why you are getting all the gaps in the print.
    Also the temp for normal PLA seems a little high, try 195c and bump it up 5c at a time.
    Edited by Carla_Birch
