Posted · Changing settings
I'm trying to figure out how to change the setting for the raft width in Ultimaker Cura.  I can figure out how to make the setting visible, but I have no idea where I can actually see it and change it's value...
    there's a parameter called "build plate adhesion type".  Set that to "raft" and then all the raft settings will be accessible.
    Note that raft is an old technology - not used much these last 7 years or so.  It was used back in the day before PLA became popular and before heated beds when we just had ABS filament only.  It was the only way to get parts to stick to a cold bed.
    Now with heated beds, and ABS glue stick and PVA glues and so on, it's just not the preferred method.  It gives an ugly bottom to the print when you remove it.  And I suspect the makers of Cura have never used it for it's original intention so probably didn't make it very flexible (which is what you need so the part can shrink without separating from blue tape or whatever type of bed you have.
    I've discovered it's really useful for what I'm doing in helping maintain consistent prints for really small pieces.  I hate using it for the wasted PLA, but it's saved me several botched prints.  I had generally good luck with a PEI surface, but once I tried to do multiple pieces, it got inconsistent, which is why I've started using it here.
    It sounds like your bed isn't as flat as you need and the raft takes care of this.  What kind of printer do you have?  Does it have multipoint leveling?
    It might be worth it for you to make your print bed super flat using shims or something and a good straight edge to test flatness of the bed.
