Hi SandervG:
Thanks for getting back so quickly.
This issue is 0.15mm (150 microns), so is not detectable to the human eye.
I've added a couple of pics anyway.
Largest diameter visible is 65.0mm.
This is an assembled component consisting of.
Black ABS - Main Body.
Silver ABS - Disk Insert (This will be replaced by Turned and Milled PEEK in the final use part - not printed).
Black Nylon - Centre Locator.
There are other Stainless Steel inserts and fixings present (not printed).
The ovality encompasses both X and Y to almost equal degree (i.e. both axis combining to give ovality).
Ovality is consistent in both magnitude and direction (therefore this indicates actual mis-calibration).
The machine is stable and does not rock or move.
Machine is in humidity and temperature controlled environment.
I have the additional Accante top enclosure to aid temperature stability.
I print with pretty much every type of material (PLA, ABS, PP, PET, Nylon, PC, PET CF, PAHT CF, PP GF, PA GF etc. etc.) and always found the print quality to be very good.
Only other issues I have had, has been blocked nozzles and dirty feed wheels which accidentally trigger material out alarm. However, both of these issues are to do with printing composite materials and are simple cleaning jobs.
Aside from this, the machine is kept clean and is looked after. I gentle wipe the slide rails clean and oil them once every few weeks, along with greasing the lead screw and cleaning the feeders.
I first noticed the issues several weeks ago and found that the main culprit to be loose short belts. However, this got me looking and digging deeper, trying to improve the ovality (roundness) issue. Can't say for sure how long it has been there before this, as have not had to do such a size and shape sensitive part until now. It may well have been there since the start.
This type of problem is usually calibration related on most CNC machines and can usually be adjusted in soft settings to cure the problem. Obviously with the S5 being a far simpler device, I would imagine that the adjustment is only possible by hardware, hence asking. However, if stepper motor calibration is possible, this may be the answer.
Many thanks.
Sketch
SandervG 1,499
Hi @Sketch, thank you for your message and welcome to the community!
Would it be possible to share a photo of your print?
About your ovality, you say that it is 15mm. Is it always 15mm off in a certain direction, or a percentage? If one direction is 15mm off, is the other direction dimensionally accurate or just ~15mm less inaccurate?
Is your Ultimaker stable on its feet, no corners lifted from the surface it is on? Have you ever had any other issues with the Ultimaker that you resolved, or anything else that may not be as it was out of the box?
Thank you,
