33 minutes ago, Smithy said:It helps if you turn on Coasting temporarily to see the location of the seam.
Thank you that's a great tip!
I found that if I play with rotating the model as well as trying a few 'Z Seam Position' options I was able to make it put the seam always on a sharp corner. Not a global solution but another tool in the box.
I had always put rectangular objects parallel to the axis with the assumption it would print more perfectly square, but I might change that behaviour now!
Smithy 1,135
For your other questions, let's wait for the Cura experts here....
