Maybe the STL file is too big? Not sure but this is one possibility.
How big is the STL file? I would try exporting a smaller STL file with fewer triangles. Try to keep it below 1 million triangles (about 50MB). I usually aim for 100K triangles in my STL file. You can change the settings in fusion 360 on the export step or you can decimate (reduce) using this wonderful method:
The nice thing about meshlab is that it also tells you how many triangles the STL has when you load it and also again at the bottom of the screen. Meshlab is quite fast.
gr5 2,243
http://www.shapeways.com/tutorials/polygon_reduction_with_meshlab
