Ultimaker not working after incomlete FW update
me0815
Posted · Ultimaker not working after incomlete FW update
Hello,
Ā
While I was updating my UM2 FW suddenly my Laptop crashed šŸ˜ž
When I then wanted to update the FW again, I noticed that the ultimaker doesnt work, the display shows noting, the board is bliking and the LEDs ar lighting a little... and the worst: I cannot connet it with my Laptop(also tried it with my PC and with diffrent cables)
Ā
So do you have any suggestions???Ā Ā Ā Ā Ā Ā  (a reset knob on the boardĀ  is misssing xD )
Ā
Best regards,
Ā
Tom
Ā
    Hi
    That sounds like you have bricked up the printer, @gr5Ā is likely to know how to recover it, normally the main controlboard as a sd card on it you can take out and load onto a computer and you will need to copy the files back to it, so hopefully gr5 will be able to tell you the steps for this and point you to the files.
        Ā
        Ā
        Ā
        Ā
        Ā
        Ā
        Reliable bed tilt compensation (no more thumbscrews) 2.4 and 5 GHz Wi-Fi A 1080p camera (mounted higher for a better view) Compatibility with 280+ Marketplace materials Compatibility with S5 project files (no reslicing needed) And a whole lot more Ā
      • UltiMaker Cura Alpha šŸŽ„ Tree Support Spotlight šŸŽ„
        Ā
        We generated a special version of Cura 5.2 called 5.3.0 Alpha + Xmas. The only changes we introduced compared to UltiMaker Cura 5.2.1 are those which are needed for the new supports. So keep in mind, this is not a sneak peek for Cura 5.3 (there are some really cool new features coming up) but a spotlight release highlighting this new version of tree supports. Ā
