Merging models in Cura
GregValiant
Posted · Merging models in Cura
Occasionally I'll get an STL file from someplace like Thingiverse and I will want to add printed text to it.  I import the model into Cura and then bring my text in and embed it in the first model with some of the text object a few layers higher than the model.  Cura prints the text and the model as two entities as if they were separated on the build plate.  As the image shows - the infill prints and then the letters print in the area where the infill already exists.  Once the print head is above the first model the problem goes away.  But the over-extrusion in the areas that the two models overlap causes missed steps and/or blobbing.  What I want is for Cura to see them as a single model and slice it accordingly.  This isn't a problem if I design everything because I can create a union in ACad and Cura will see a single model.
I have played with commands that include the word "overlap" but there are still double lines on each layer and I've tried a couple of things with "per model" settings but they didn't work.
Is there a way to fool Cura into seeing a single model?
    Posted (edited) · Merging models in Cura
    Export your loaded models into Cura onto a STL file, then get back this file into cura. It should be considedered as a single model.
    Same issue as
    Edited by Cuq
    This creates overlapping volumes, which may not print well. Be sure to have the "Union overlapping volumes" setting enabled, and check the Prepare view before printing.
        • 21 replies
