Cura Hangs after Multiply operation - reaches 100%
GregValiant 1,305
This is a trick I just learned here. It might work for you.
Multiply the model 10 times.
Export the model as a binary STL file. All 10 instances will be exported as a single entity.
Clear the build plate.
Open the new STL file.
Multiply the new file 10 times.
You get 100 pieces on the plate and hopefully you won't run out of resources.
