15 hours ago, UlrichC-DE said:ER998, ER63, ER52, ER56, ER65, ER57
With Material Station, I had a new surprise after or before each print.
Amen. I'm new to UM, having been most familiar with Lulzbot previously. To this point have not been impressed with UM. It seems there is forevermore something wrong, aborted prints, etc. Perhaps it is due to the Material Station.
15 hours ago, UlrichC-DE said:Also sporadic effects such as empty spool turning and spool not turning.
I have probably finally found the main cause of the errors. I had previously checked ER57 and therefore all Bowden.
Maybe interesting for others:
The Bowden from the Material Station Material Sensor to the printer feeder was not installed properly. The Bowden hadn't been inserted deep enough in the material sensor or had come loose.
They were pre-assembled on delivery, so I didn't have them on my screen at first.
The first Bowden was long because of that and not fastened enough. This sometimes confused the material station when unloading.
The profiles for unloading could not be carried out properly.Had the problem on print head 1. But it also transferred to print head 2. Probably because the feeder is not started up like the first one at the start (time is money).
Printhead 1 was almost not extruded at start up. On the other hand, the filament ran at full throttle in extruder 2.
- This often caused the PVA material in the bowden to break.
- Other materials reported clogged printhead even though it was unaffected.
- By extending the bowden on extruder 1, I had the usual "Can't unload material" problems at the end of printing.
For TPU95A filament, this was probably expressed in ER998. With other filaments ER63. When unloading, the station moves back a certain length of the filament.
First warm pull then cold pull in millimeter work. If the bowden is too long, only the tension from the filament is relieved. But the filament in the extruder doesn't move a bit.
(I don't have any technical documentation. Therefore, I can only observe and draw conclusions.)
I'm not following your thoughts on the Bowden length, but I have had repetitive problems with the collets slipping in the decoupler, and have learned not to trust them to stay put.
I'd be interested in hearing others' tips on how to smooth out the myriad of errors that seem inherit to the S5 Pro Bundle. The design is still quite unstable in my limited experience (6 months).
UlrichC-DE 107
I've had a lot of problems with the material station in the past two weeks. I had printed with Ultimaker machines for many years before and had no reason to go through the forum.
I couldn't see the problem from the outside. It looked like the first day. I loosened the clamp and brought the Bowden into position.
So far, the printer has been running without errors for three days, one of them with the new software.
Hope the mistakes don't come back.
Thanks for watching
UlrichC-DE 107
addendum. At the moment after the printer starts, it looks like in the picture on the bottom of the printer. Before that, he had barely extruded when starting. Most of the time, the filament did not come at all or just before printing.
