Difference between Initial Layer Height and Z-offset?
Posted
· Difference between Initial Layer Height and Z-offset?
Yes from my understanding there is a difference between the two. Basically the "initial layer height" setting make for a bigger first layer height but keeps the nozzle gap the same, so for eg if you got a 0.05 gap between the nozzle and build plate that gap will stay that and it will print the first layer.
Where the z-offset plugin makes the gap between the build plate and nozzle bigger, what can be handy for filaments like PETG that need a bit of a bigger gap due to how well they stick and like to stick to a nozzle when pushing down the first layer. Can also be handy if your printing onto a fabric over the build plate.
Posted
(edited)
The Initial Layer Height will affect how much material is extruded. If you make a "thicker" layer, more material will be extruded to "fill" that layer. A thinner layer results in less material being used for that first layer. Changing the initial layer height will not "squish" the print more or less into the buildplate.
The Z Offset does not affect how much material is extruded, but only how close the first layer is printed to the buildplate. A negative Z Offset will squish the print into the buildplate. A positive Z Offset can make it easier to remove a print from the buildplate, while increasing the risk of the print coming loose during the print.
The initial layer height is used to compensate for a buildplate that is not entirely flat or well leveled. The Z Offset is used to increase or decrease buildplate adhesion. They are two different tools for different goals.
Posted
Thank you for that very clear explanation. Very helpful.
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
Carla_Birch 114
ahoeben 1,602
Edited by ahoebenLink to post
mkoic 1
