Problems with second extruder in CURA. (Leapfrog Creatr HS)
Posted
· Problems with second extruder in CURA. (Leapfrog Creatr HS)
Hi Michael,
I had the same issue as you and you made me understand what is wrong. The issue is located in the start g-code. It is actually missing the setup for the left extruder.
I've managed to solve this by duplicating these lines and adding a start line for each extruder
https://marlinfw.org/docs/gcode/T001-T002.html
printer start g-code
M107 ; start with the fan off
G28 X0 Y0 ; home XY axes
G28 Z0 ; home Z
G92 X0 Y0 Z0 E0 ; reset software positions
;*** Start Dual Nozzle/Bed Preheating ***
M140 S{material_bed_temperature_layer_0} ; start preheating the bed
M104 S{material_print_temperature_layer_0} T0 ; start preheating hotend
M104 S{material_print_temperature_layer_0} T1 ; start preheating hotend
;*** Wait until temperature reached ***
M190 S{material_bed_temperature_layer_0} ; heat to Cura Bed setting
M109 S{material_print_temperature_layer_0} T0 ; heat to Cura Hotend
M109 S{material_print_temperature_layer_0} T1 ; heat to Cura Hotend
;*** End Preheating ***
G1 Z15.0 F180
T0
G92 E0 ; zero the extruded length
T1
G1 E3 F200
T0
T1
G1 F225
Left extruder start g-code
T1 ; Selecting tool
Right extruder start g-code
T0 ; Selecting tool
fyi; left it T1 and right is T0. It is not a typo
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
frankforpresident 0
Hi Michael,
