Thank you for this very extensive and detailed answer.
- I first tried to rotate slightly counter-clockwise the potentiometer > still very small and irregular steps for 10mm request
- then tried to rotate slightly clockwise the potentiometer > still very small and irregular steps for 10mm request
- then tried to rotate 30° clockwise the potentiometer > still very small and irregular steps for 10mm request
- launched the test for 1 mm request > movements are near the same than for 10 mm request
- then I removed carefully the stepper drivers X and Y (it was not difficult) and placed the X stepper driver in the Y slot > same wrong result.
Let me know if I can make some additional testing or how to be in touch with support about this issue.
Thank you for your cooperation.
F.
gr5 2,330
Under your UM, on the electronics board, you will see 4 smaller boards. One for each of the 4 axes (plus a socket for a spare extruder if you do dual extrusion). These are sometimes called "stepper drivers" or "pololus".
There is a small potentiometer on there that you can rotate. It sounds like you might need to increase the current a tiny bit. If you turn it too much your stepper will gradually get very hot.
http://wiki.ultimaker.com/Electronics_build_guide#Tuning_the_stepper_motor_drivers
You could instead swap two stepper drivers and see if the problem moves. If it does you can write a ticket and they will probably ship you a new one for free on Monday.
If you choose to remove a stepper driver, it is easy but do it very slowly and carefully. Don't rush. Use something like a screwdriver to pry up one side part way. Then switch to the second side. Then go back to the first side. Go slow. It should take 2 or 3 prying tries. If you go too fast you will bend the pins.
