With “by hand” I meant, that it’s not done by Cura. 🙂
As in nearly all cases, the amount of filament the hotend can deliver is the limiting factor to printspeed(s), Cura should be able to handle this.
Interesting.
Does anyone know what the maximum volumetric flow rate is for an Ender 3 Pro with stock hot end? I guess this would vary depending on nozzle size, material, printing temp … ?
Edited by mkoic
GregValiant 1,488
The formulas aren't complicated for a basic computation. I suppose a plugin could be written with a dialog box to fill in the flow parameters and do the math in the background. I use a simple spreadsheet and enter the parameters in a few cells and the answer shows up at the end (mm^3/sec or even E-steps/sec). I suppose it could be considered doing it by hand because I'm using a keyboard. That would be true of a dialog box as well.
