The behaviorĀ isĀ more or less normal. The leveling sensor is a capacity sensor and measures the distance between the head and the build plate. The build plate moves slowly upwards and the measured value of the sensor changes during the move. Then the nozzle touches the build plate, and then the build plate moves a little bit further, but the measured value doesn't change anymore. That's the point where the printer knows the exact distance, the height of the bed when the measured value gets stable.
Ā
You can also see that the bed slightly bends in one direction, just a little bit, this is also normal.
Ā
ButĀ the bed screws are also important, they should not be too tight and also not too loose. The springs under der bed should be able to work, so choose something in the middle. On the other hand when leveling is working, I would not touch it.Ā
SandervG 1,521
I don't think so, did you adjust the bed screws? Perhaps they are too high. But it is no mechanical error, just a misconfiguration and should be relatively easy to correct.Ā
