... instead of getting frustrated You should have remembered how you started printing with your ender 3... probably by using the Micro SD-Card...🤪
If you really, really, really need to print things, forget printing via USB and start with using the Micro SD-card...
And @tinkergnome is right, use a dedicated print-server like octoprint, that is way, way better then using Cura for that!
tinkergnome 926
Hi @gamergirl4,
Cura was never meant to act as a print server - although it obviously (partially) works.
Just use the (micro) SD-card and enjoy a device that prints stand-alone.
Alternatively (or if you insist to print via USB cable 🙂)
Better use a dedicated print server like "Repetier host" or "Octoprint". Both are free to use.
Happy printing!
