I do not get the Support blocker to work.
Have tried to remove support on models I make but the tool only turns gray and there is no option remove or add here.
It is not possible to add/remove support at all in my version of Cura 4.11. Or at least I have not found a way to remove it.
It says I need to slice the model first and then when I look in preview I can see supports but there is no way of removing them.
Also there are no options available when clicking the Support blocker, it only does one thing and I do not understand what it does, because nothing happens except those gray areas, huge blocks that are present on the screen, and when I go back to the model I need to slice it once more and the standard supports are there as usual.
Is there some tutorial for this somewhere?
Have been looking at many places but not found anything.
GregValiant 1,307
On the left of the Cura workspace screen is a toolbar. The bottom tool is "Support Blocker". Select your model and then select Support Blocker. Click somewhere on the model to create a block.
On the lower left there will be a list of the objects on the build plate (oddly enough called the "Object List"). Your new support blocker will be Eraser and additional blocks will be added to the list. You can make them active by selecting them on the list.
When you select the Eraser block you can drag it around or type numbers into the Move tool dialog. You can also scale it separately in all three axis. When it covers the proper section of your model you can also elect to have different settings for the intersection volume between your model and the blocker (it's under "Per Model" settings just above the blocker tool). I found that if I wanted to block support AND infill from an area that I needed two blocks covering the same area with one set to infill and the other set to support. I haven't played with that aspect of Cura a lot though.
deonholt 0
Thank you very much for a very thorough explanation. Really appreciate your help & time. I got it to work.
