Tips for heavy printer use? Or Recommendations for outsourcing printing?
Posted
· Tips for heavy printer use? Or Recommendations for outsourcing printing?
Printing 4h/day is not that exceptional. Here on the forum I have seen people who print almost continuously. If you do regular maintenance on your printer, it should be fine: nozzle cleaning with atomic puls, cleaning and lubricating rods, removing dust and hairs from the fans, cleaning feeder wheel,...
Or you could try moulding and casting: 3D-print a master-object and a shell, carefully post-process these (=sand, smooth,...) and use these to cast a silicone mould. Then use that mould to cast plastic items. On Youtube you find a lot of good tutorials on moulding and casting. Then you combine the best of 3d-printing and moulding and casting.
geert_2 557
