Ok. i learned alote since i posted this question 🙂 Now, the main problem is that this file have 800mb and when i click Slice, just standing there doing nothing... Do i need to w8 long time to finish slice or (object has 18mil faces )?
18 million faces? in 800mb? yeah that's too big. Just glancing at the part in the photo above I'd say 10,000 faces should be enough so you can decimate by 1000X. Or just try getting it down to 200,000 faces (100X smaller file).
Here's an easy, free way to reduce number of faces/triangles:
http://www.shapeways.com/tutorials/polygon_reduction_with_meshlab
So i can do that if i only have STL file
You don't have an STL file? That's strange. What kind of file do you have?
gr5 2,333
The red area isn't anything "bad" - it's just showing areas of the part facing downwards.
I'm more worried about the "manifold" part. If there is a problem with that you will see it in "preview" mode, not "prepare" mode. Anyway, back to making the model flat.
You have a few options:
1) Rotate as flat as possible and then cut off a little
2) use support or raft
3) Fix the model so the bottom is flat
So #1 above: rotate as flat as you possible can, looking from many angles. Get it within 1 degree. Then go to "preferences" "configure cura" and uncheck "automatically drop models to the build plate". Remember to check this again after you are done with this part. Now select the part and on the left side use the top tool (move) and adjust the Z value to be a negative value to sink the part below the surface until it is cut off flat. Then print it. Realize that the part will now be a slightly different shape. If you are lucky you can slice off less than 0.1mm which will basically not change the part significantly.
