1 hour ago, IRobertI said:Try making your wall thickness just slightly thicker. Or reduce the line width setting in Cura a smidge. There's also a setting called horizontal expansion which will artificially make your walls a little bit thicker. Pick one of those three and you should be good to go. Basically what's happening is that it's an edge case for the math involved in creating the line segments.
Thanks!
Horizontal expansion on 0,01 mm helps 🙂
IRobertI 521
