I was using the GUI to input values, but your post gave me a better idea.
I copied the .json definitions file from the supplied software build into the definitions folder for 4.7. I'll see what happens when I slice and try to print. Thanks for the help.
gr5 2,210
Are you changing these in a file? Or in the Cura GUI? I don't know much about creality but the cr6 looks like the cr10 and there are definitely cr10 machine's built into cura. Maybe start with cr10?
So you might want to edit the json file with your printer settings. The printer definition files are in a "definitions" folder *somewhere* on your computer (no idea how to find this folder on a PC - maybe in c:/program files/ultimaker/?? They have the extention ".json". Search for files that have "CR" in the name and end with ".json" and that are in a "definitions" folder.
And finally this might be horrible advice as I've never tried this but you can edit all the settings through a plugin:
Click "marketplace" in upper right of cura, make sure you are on "plugins", scroll down and alphabetically among the "P"s is "printer settings" plugin.
If you edit any json files then make sure to restart cura to get the latest machine settings loaded into cura.
