GregValiant 156
I won't comment on any skill deficiencies you may or may not have. I have trouble enough with my own. I remember COBOL. I cut my teeth on an IBM360 and Fortran while at GM Fisher Body.
The finer the model, the smoother the print. I think that's how some of the machine manufacturers spoil their new customers. They provide them some Gcode files that were sliced by extremely competent people using extremely fine models and the prints come out superb. Then the user can't duplicate the superb model because the files downloaded from a website aren't near the resolution of the canned files. No amount of fiddling with settings can get a rough model to look like a fine model.
1
GregValiant 156
Holes like to come out undersized. The plastic is viscous enough that it gets dragged towards the center as it extrudes. @gr5 calls it the "Snot Factor" and the smaller the hole the worse it is.
Under "Shell" you'll find "Hole Horizontal Expansion" and it will get you much closer. It is an offset setting and so it acts on the radius. Your diameters are off by about .8 so set the Hole Horizontal Expansion to .4mm.
Another thing - is that image of the part accurate as to the resolution of the STL file? Check in TinkerCad and see if there is an option for a higher resolution when it generates the STL file. A part with so few facets around the diameter will have it's own issues as the plastic gets dragged across the facet angles effectively making the hole smaller.
grNadpa 1
Terrific response. Just wanted to make sure that my skill deficiency was not the issue in this case. Thank you. Will look for "Shell".
Yes, Tinkercad does provide a way to add additional "sides" to circle / cone / etc. objects. I just take the defaults, for now, as I endure the learning curve of this "new-fangled" software [being a retired Mainframe Computer applications guy that made my living in COBOL and CICS].
