The string lines are the shortest distance between the points and the arrowhead so Cura may have decided that it's the most efficient path.
Have you tried Combing mode? It makes for a lot of movement on a part like that since it would want to stay over the walls at all times. Moving the Z seam and the Layer Start points can have an effect too. That's a tough part though with those inside corners. Have you tried rotating the part on the bed to put one of the short points right at 6 o'clock? Then put the Z seam in "front".
GregValiant 1,110
DivingDuck 94
optimize wall printing order = on
z seam alignment = shortest
