Hi! Thanks for the reply. I'm not concerned about the edges where the tree supports are. they are just supporting the sides of the "slice" of the model. In the pic is the start of the print of the layer. You can see the triangle outline and then the gcode moves to the air gap and starts printing in mid air. I'm going to fix part of the problem by extruding the "floor" of the jar downward so it touches more of the model, but I'd like to have the gcode start at the inner edge of the outside triangle and work in. That way the plastic has something to adhere to. I've add a few pics for clarification. One is what it's doing in my test print. The other is a "core" piece I printed that shows what the effect is supposed to look like. The core was printed upside-down so the air gap wasn't an issue with that print. Please let me know if you need more pics or have more questions.
Thanks!
Steve Hurd
gr5 2,210
I don't understand the question. You are talking about that small triangle - right where the nozzle is - in the photo above. Right?
If so:
1) Is that the begining of some kind of support? If so then there is something called "support blocker". I'm pretty sure it existed back in 3.6 as well.
2) Or is that part of the model in which case... what do you want cura to do? Is your model a tiny triangle hanging over nothing? And if so how would you expect it to get printed?
3) Or is that entire region supposed to be filled in but you haven't shown us that yet? If so, that shouldn't happen - there's a feature called "bridging" that spans areas like that with long straight lines supported on each end. Or maybe your part bottom isn't level here and that's the issue.
Anyway, we need to know a little bit more about the level you are showing now - what does it do next? And is it printing model? Or infill?
