Right, this sounds like one of the belts is climbing on the side of a pulley. Normally this will create particles in the bottom of the printer (one of the four corners) and this will collect up here as small black ones..
The two short belts might be addressed, if one the pulleys is coming loose this might happen.
Thanks
Torgeir.
Edited by Torgeir
Torgeir 248
Hi oskars,
Thanks
Torgeir.
