@Smithy thanks! Will experiment with that. If the temp was the issue, won't the whole surface be messy in the top layer? One side of the top layer is coming out great while the other side is this bumpy mess.
Is it possible that there is some dirt in the slider beams which is causing this unevenness or could it be something else?
PS smaller prints come out great. It's just that when I do bigger prints around that area of the print bed, things start to get messed up.
Edited by dskux
Smithy 1,146
I guess you mean the top layer which looks messy?
Try to print more top layers and/or try to print cooler. I think the base plate is not so thick, so it would be better to avoid that there is one or two layers of infill, print it solid with more top/bottom layers. But if it is thicker infill makes sense, but then print more top layers 5-6 to get a smooth surface.
Your levelling and first layer looks ok to me.
