Another thing I forgot to write was, that if I remove the bovden tube and push a short piece of filament through the extrudor, everything works fine. If I made a cold pull, everything was clean inside, because I could see light through the nozzle hole, so assuming something gets clogged there isn't the case.
I have a feeling that something gets stuck at the point where the bovden tube connects to the small white connector which goes to the teflon part. Then again, like I said, the printer worked for a couple of minutes and extrusion slowly stopped, so I am left without ideas what to look for.
@gr5 I remember 6 years ago you had all the answers to my issues. If you have any ideas, what would be the case here?
Edited by mihc
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
mihc 0
Edited by mihcLink to post
