Posted
· Ultimaker S3 - Violent change in directions
Hi twetter,
Welcome in here.
This acceleration/speed is quite normal for this setting I'll think, if you reduce the "traveling speed" this vibration effect will be reduced. I'd reduce it to the double of the printing speed, say 90 mm/sec.
Thanks
Torgeir
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Torgeir 228
Hi twetter,
Welcome in here.
Thanks
Torgeir
