Hello Torgeir - thank you for taking the time to help.
I have also tried another method. This is explained below.
First, I model exactly as I would like to print. A hollow tree with 1.2mm wall thickness and cylinder cut from the bottom. See first picture below.
Add the STL to Cura, set infill to 0% and slice.
A very similar result is produced. Any ideas here? Maybe there is a settings I need to turn off in Cura?
Torgeir 247
Hi pander1405.
Welcome in here.
Here was little information for sure, -however, you tree seems to be "all solid" so you'll need to define the wall thickness.
Maybe better to set number of wall layers single wall one, two, or what you want.
You might need support, -or maybe this can be printed without using support.
Good luck
Thanks
Torgeir.
