Imported model shows on build plate with light gray and yellow stripes
rwebcon
Posted · Imported model shows on build plate with light gray and yellow stripes
I can not figure out why this is happening.  With same profile and materials other model import fine.  I'm new to Cura but trying to learn!
    Cura thinks the model does not fit the buildvolume. From the screenshot it looks that it does fit, but maybe there is an additional part included in the same model that is outside the buildvolume?
    Can you share the model?
    The model is overlapping with the prime tower, so...
    switch the prime tower off (if you don't need it), or move the model (or the prime tower) to a different position.
    • Like 3
