Reverse support block
DDDPrintno
Posted · Reverse support block
If I understand you correctly, you want to use the blocks as support.
If this is your question, then it is possible.
Place your block on the model, then just choose the block. Then choose the mesh-type feature (5th on the left side) and choose print as support.
This works also with all other models.
I link you a thread to a similar problem (the idea is the same).
