So, I tried to move with both cables, pull out from connector and get back agin. Still same problem...only message "Reading card". Oppps.
I do not like fold of the cable on the input exp1...look at pic.
https://www.dropbox.com/s/tzmoi98ffdax0bo/um2_sdcable.jpg
It is right that one of the cables (white, blue) is freely?
https://www.dropbox.com/s/ufvjc68l6q7ml9b/um2_sdcable2.JPG
gr5 1,968
Most of the problems with the SD card are fixed if you move the ribbon cables just a little bit. Remove the larger cover on the bottom of the UM2. There are 2 gray flat cables in the corner. Try moving them away from each other maybe and try leaving the cover off. See if that helps.
