Exactly: print as slow, cool, and thin layers as possible. And, depending on the model, print multiple items at once, so the hot nozzle is moved away and the parts have time too cool down and solidify. Otherwise they stay molten.
For more complex models, I also print a dummy tower (with inverted shape) next to the real model, for this cooling, and to make the printing time equal for each layer. Big changes in printing area do produce horizontal lines, due to differences in cooling time.
See these:
Left: printed without dummy tower, right: with dummy tower. This reduces the effect, but does not eliminate it.
Dummy tower with inverted shape, for increasing and equalizing printing-time per layer. Concept model.
Idem, real model.
DivingDuck 104
These kind of parts should be printed more than one in a print as you will maybe don't have enough time for cooling an actual layer. Print slow (all speeds should be the same, except travel speed) and with small layer high. Looks like you also fight with over extrusion, maybe reduce flow a bit too.
