Your main issue is that the first layer is too high off the bed (I think - would be best if I could see the first few seconds after it starts). Does your printer do autoleveling? Manual leveling? for most printers, manual leveling is better so if that's what you are doing, just move the bed a little closer to the nozzle while it prints the bottom layer until it sticks nicely.
GregValiant 1,318
The first layer isn't sticking. There is no top or bottom to the shell (but that may be how you want it). The first layer height is 0.3 which may be a bit far.
In Cura:
Add a skirt to get the plastic flowing before starting into the model.
Change the Initial Layer Height to 0.2mm. That should give it a better chance at sticking to the build surface.
Check your Printer Profile and insure that your nozzle is what you actually have installed. The line width is set to .4 but width-wise nothing is connected so it's possible you have the nozzle set to something smaller.
If you still have trouble, then try setting the Initial Layer Flow to 115%. The point is to get that first layer down. After that it can go back to 100%.
