Create your own printer-profile!
- 1 month later...
I just one for my son for Christmas and ran into the same thing. It even came with Cura on SDcard to use. I think there is a newer version then is available, so I’ll try that and report back. There is also newer firmware, but of course that address this topic.
GregValiant 1,492
Unless you know that some other production printer shares your printer size, firmware flavor, etc, you have to add it as a "Custom FFF" printer. After adding it and selecting a name, go to Machine Settings and make changes to the bed size, shape, and the other things there. Very few non-delta printers use Center Zero so make sure that is turned off and you need to select the proper "Gcode Flavor". If you are unsure of the "flavor" start with Marlin, but you really need to check with the printer manufacturer and find out for sure what firmware the printer runs on.
The "Print Head Settings" (X Min, Y Min, Gantry height, etc.) don't become involved unless you were to select "One at a time" as a print mode in Cura.
guschavez 0
Ever figure this out? I am in the same situation now.
