Can anyone tell why there is a pause in this G code?
bigone5500
Posted (edited) · Can anyone tell why there is a pause in this G code?
... please share the project-file with us: File - Save Project...
Then we not only have the object but also your printer settings...
Did you not accidentally set a option/command under Extensions - Post Processing - Modify Gcode
Edited by Mari
    Posted · Can anyone tell why there is a pause in this G code?
    So I started printing the right hand side arm. I sat patiently and waited to see when the pause would happen. It actually happened twice. At approx 39m30s in, it paused and I quickly pressed the knob and it continued. It completed another pass and stopped again. This is when the message went away on the display. I will attach a photo of the location that it pauses. You will see the point at which there is a small curly Q. 20201108_183243.thumb.jpg.8106ba15c8ddd144e46f02820cf89c6b.jpg
    6 hours ago, bigone5500 said:
    Would printing over USB have any effect on this?
    That is probably the problem... put the gcode-file on mirco sd-card and print with that! Cura isn't really designed for printing over USB...
    Edited by Mari
    I will use SD cards from here on out and see if the issue persists. Thanks!
    Edited by bigone5500
