DivingDuck 60
What is Cura telling you when you open the stl file? This looks like you have a problem with your model.
Anyway, I like to add a thought I had as this happens in 95% of user requests for help here:
It is good practice to attach a project file so that one who want to help can have a close look to your model and your slicer setup. Without this it is often not possible to give you an good answer, as most of people havn't a magic crystal ball. I too still try to find one. 🙂
2
VanTheuni 1
So I did a few tests and it looks like both versions are more or less having the same "problem". I designed this model pushing the 45° borders to the limit. Meaning I jumped forwards and back from Blender to Cura to stay beneath the 45° angle and it looks like I created a model that gets newly interpreted with every import (without changing the model) whether it is within the 45° rule or not. Sometimes it is and sometimes it's not. I did some analyses with Blender (it has a neat plugin for checking data for 3d print) and indeed there are around 70 faces above 45°. So now I am a little unsure concerning what I actually see in Cura regarding the warning display of print models.
Has anyone in the community made long term experiences with that part of Cura?
