Tree Support
cjs28
I just downloaded Cura 4.8, and I cannot seem to find the "Enable Tree Support" setting. I know it is typically under the Experimental section. I had an older version of Cura, and that is where it was. Everything I have seen online says it is there as well. It is not there when I search for it in Cura 4.8 though. It gives me the tree support setting in the Support section like "Tree Support Branch Angle" and "Tree Support Branch Distance," but I cannot find where to actually turn it on.
Thank you
        • 4 replies
