Ok, I did a couple of tests. First, the same stl file printed the internal threads when the object was horizontal. Too bad they are threads and a cylinder that need to be printed vertically.
Next, I reloaded the stl and looked at the preview, and in fact the internal cylinder and threads appeared as infill, which is how it printed (no top or bottom layer, just exposed infill). I guess I missed that the first time.
I then loaded 4.7.1 back and it renders fine. So it is definitely a bug in 4.8.
Let me know if you want the stl. Like I said its pretty basic and it would probably be faster to design one than wait for me to send it. I designed it in fusion 360 if that means anything.
I'm sticking with 4.7.1 for now.
Labern 775
Did it show the threads in layer view? Or just in the model view?
