2 minutes ago, Smithy said:Can you elaborate it a bit more? I also use 17.10.1 but haven't seen the bug yet.
Sure 🙂
After a print ends, you let everything cool down and then start a new print, it can happen (it musn't) that the system doesn't register the endstop switches and drives the printhead into the corner till you abort the print or cut off the power.
The reason of this could be the geek mode, disabling it can provide less stress on the system, as i read it.
I powercycle the machine now after each print, i don't want to change the belts tjat early.
Smithy 1,088
