On 11/18/2020 at 4:57 AM, Carla_Birch said:It could be a few things, whats your print speed btw?
It could be your over all print speed is to much, but i think you have another problem looking at the top layer of the base i can see that the paths are not all joined to each other and you got gaps between them. This could be filament size settings, line width settings and filament flow.
If you go to file and save project you be able to upload your 3MF file to the post and this will let people see your full settings.
Print speed is 50 mm/s, infill 50 mm/s, top/bottom 25 mm/s. I see what you mean about the gaps, but didn't think they were significant enough to worry about - so I should be getting a better quality out of the top face you think?
I forgot to save the settings, but haven't changed print speed and flows.
Flow is all 95%, I have this extruder with e-steps changed to 139 from stock. I found 95% flow to give me approx. +/-0.02mm on a calibration cube. Line width set to 0.4mm.
Carla_Birch 115
