Dim3nsioneer 557
Maybe you guys could improve your assembling workflow to add a visual check at the end to see which fan is running. Might be bad if the 3rd. fan does not work and the first Ultimaker experience is ruined by a potential filament plug.
I can only recommend Ultimaker to introduce Poka Yoke for the UM2 electronics...
gr5 1,971
Yes. I didn't get one but the newer um2's come with one. Slip it into the holes on the back of the UM and twist.
