And Cura-ZOffsetPlugin too, though the Linear Advance one is a bit nicer because it uses a "familiar" json file instead of a dict.
Note that the method I use in both plugins is not officially sanctioned. There is some "illegal" access to "private" variables, and it is a bit of a magic incantation that seems to work. It might break at any Cura update, though the method of adding settings has been fairly stable so far. I did my best to document how it works.
1
nallath 1,063
I think one of @ahoeben's plugins also adds an extra setting to the setting list. I'm not sure what trick he uses for that.
Tyronnosaurus 7
Nice memory, nallath. Looks like it's Cura-LinearAdvanceSettingPlugin. I'll check it out.
