Thank you. If I want to have different sets of settings for different filaments/projects, is exporting the profile the approach to use?
If after printing a STL file and I want to use the same settings on a different STL, will opening the second STL file and then deleting the original STL object under PREPARE allow me to use the same settings on the second STL object?
Before I created this thread, I followed the steps in the link you provided. Under Profile, I have the following tabs: Activate (dimmed), Create, Remove (dimmed), Rename (dimmed), Import, Export (dimmed). Is the correct procedure is that I have to first create a profile and give it a name. Then, Export is enable for me to choose to save the settings? Without creating a profile, the Export button is dimmed all the time.
Edited by ultimaker_user
tinkergnome 929
Exporting is only handy if you want to use it as a file for backup or if you want to import it into a different Cura installation (AFAIK).
Anyway: The "Cura Profile Writer" has to be enabled, not (only) the reader. And according to the manual there's an "Activate" step to do first (this will enable the "Export" button).
https://support.ultimaker.com/hc/en-us/articles/360012480959-How-to-manage-printing-profiles-in-Ultimaker-Cura
