Call off the dogs. I found the problem. Seems the part was printing was too small and the print head was running over the same area before it was set. I printed it along side of another part and it came out perfect.
Stay tuned. I will likely have other problems in the future. Thanks folks.
1
gr5 1,837
Sounds like something is wrong with your Z movement. The nozzle isn't separating from the build plate the correct distance (it's not moving at all or moving too little). I'd check things like stepper motor gear - there is typically a set screw that tightens that down. Tighten the hell out of that - typically enough to twist the allen wrench and potentially hurt your fingers for a few minutes.
I'd search for other users of your type of printer as well.
I'd also manually move the Z up and down and measure how far it moved with a ruler.
It's also possible some jumper fell out and it is moving exactly half as far as it should. This is easier to diagnose with a ruler. It's common for stepper drivers to have jumpers to set the substepping.
