On the one side there is a switch, and on the other side there is something acting as the trip dog. It is often easier to change the trip dog.
Here is the fix for my Ender. The gray clip is easily removeable so I can take the glass off and go back to the magnetic pad. The narrow finger sticking out on the bottom of the clip is the piece that hits the switch. The thickness is the difference between the glass, and the magnetic pad. With the clip in place - the switch is tripped about 3mm short of where the actual frame piece used to trip the switch.
Cura doesn't know or care where the build plate is. Cura does need to know how big it is. I don't know on the Tronxy but the Home Offset numbers usually set the local 0,0,0 and then when the gcode comes into the printer, that's what is used as the origin for the print. I suppose you could go into the machine settings and make the "Z" Max 3mm shorter. I didn't bother and I don't think Mr. Spock is going to show up and yell at me.
(On a personal note, I finally got to stick my "Stoopid" logo into a post.)
Edited by GregValiant
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
GregValiant 693
Edited by GregValiantLink to post
