Oops.
Thanks so much Smithy. I appreciate your help.
It's a much better solution than a faulty machine, so I'm glad it turned out to be my design error!
Oops.
You are welcome. I think you can do a quick fix in Fusion 360.
Just press Q in F360 and select the bottom of the base to do a push pull and extrude it over the existing extrusion. Just make sure you select in the property window JOIN and not CUT.
I checked my work and found the mistake - when I added the actual penholders to the base, the Extrude command was set to 'New Body', instead of 'Join'. Rooky mistake I know.
Thanks again.
A good practice is also to use the section analysis in F360 to cut through the model and check how if looks like from the inside.
Smithy 761
The base of your pen holder is not solid, therefore the top of the base is printed in the air.
You have to design a solid model, to get an infill there.
